How do I set my Status? Everytime I receive a Forum & Communities update I am advised I have not 'set my Status' I presume I am a Newbie, I am referred to as such but nowhere in my profile can I find how to 'set my Status' Not terribly important but frustrating!
Hi Brhubba
Welcome to the forums. The way I change my status is to click on my profile picture, which brings up my profile. There you should see a link at the top of the screen, underneath your picture, that says "let others know what you are up to". If you click on this you get a small box to type your current status into.
I hope this helps.
All the best,
Frank
Hi Brhubba
I hope this helps.
All the best,
Frank
Thanks Frank
Have done it
Brian
