I have just purchased a Sony Bravia TV KD49XE8005 and also a Sony soundbar HT-CT290 and bought this as they are both made by the same Manufacturer and would have hoped that there would not be any issues in connections.
I have connected the unit using the optical audio cable and also an HDMI cable to the ARC HDMI socket.
I have checked that the audio settings are correctly set but find that I have a lip sync issue.
can you please help
Hi Rob,
Welcome to the Community.
We are checking this with the relevant team for you and we will update you as soon as we have a response.
Best,
Arthur
Hi Rob,
You should be able to adjust the Audio Delay in the Enhanced Audio Settings menu. Can you please give this a try and let us know how you get on?
Thanks,
Owen
Hi Owen,
I have a same issue for my new HT-CT290 with Sony TV (49X9000E).
But I cannot to find the setting location to "adjust the Audio Delay in the Enhanced Audio Settings menu" on my TV for try, can you provide more detail step?
Thanks a lot.
KK
