Hi, would anyone know if it is possible to purchase a replacement mesh grille for a Sony Sound Bar HT- X8500?
Excellent thanks for the prompt reply I will contact them
I did contact the company you suggested and decided not to go ahead with the repair. The cost of the replacement mesh is £121 and thought that was a bit expensive for a small bash, many thanks
