Sony XD93 HDR issue not automatically detecting at times,
Recently my XD93 which I’ve nearly 4 years has seemingly an issue with either my Panasonic 4K player and my Apple TV not automatically detecting HDR. I’ve high quality / speed cables. The cables are plugged directly into the TV. The external ports are set to advanced. ALL software updates are in place. I can turn the HDR on Obviously via the picture options - but that is not the point!
its more so been an issue with the Apple TV. All settings are ok and cable rest is ok. If I turn off the advance settings on the port which enables the 4K HDR And set to standard the tv resets - if I then enable it and it resets again with 4K HDR then the picture will be fine.
I don’t know what the real issue is...is it the TV faultering?
Hi rosshobson,
Can you please try if a restart of the TV solves the issue?
Please unplug the TV for about 10 minutes form AC and the plug it back in.
