Hi, I’m currently living in Italy and I’ll be here for 2 years but I’m not sure why my turntable won’t work. I have used a converter and a transformer to plug it and it still won’t work. I’m not sure what to do?
All you need is an adapter for an electrical outlet.
Manolo
I’ve tried that but it still won’t work
If your model is the English one, it uses the same voltage to work, 230 - 240 V AC, 50/60 Hz that we use here in Italy, so it is difficult at this point to identify the problem.
Manolo
It’s an American one, could that be why?
North American model: 120 V AC, 60 Hz
Yes and even serious if the first time you connected it with the only adapter here in Italy...
Manolo
Why is it serious? What will happen?
So the power is either disconnected or it’s burnt out, is there anyway of fixing it?
At this point I can only advise you to have it checked by a service.
Manolo
