I bought this new in August 2018 and up until last week it performed faultlessly, however I am now having issuse with the sound.
.a) There are sound drop outs which occure regulary on both tv and hdmi connection.
b) It takes between 10 to 20 secs for the chosen sound effect to come in and that is on all the the effects.
c) The sub woofer makes a popping noise from time to time.
Any ideas ?
Thanks in advance.
Hi there,
Have you tried a factory reset?
Best wishes,
M
Hi, Yes did that just after I posted and appears to be ok, So I wonder if it originated from the last update?
Fingers crossed.
Thanks
I am having exactly the same issues, popping an crackling sounds?
