So I recently bought this new camera "Sony HDR-CX405" and it says it films in HD, I tried to film while walking and some non moving pictures and when I transfer the files to my pc the films are blurry and not in HD at all!
Is there a way to fix this? like in the settings or so?
Thankful for answers!
Hi Weentoz
Thanks for your post. We are looking into this and someone will get back to you shortly.
Regards,
Pete_B
Hi @Weentoz and Welcome to the Community
I'm not sure what the default setting is for video but you can change the recording
image quality and size in the Menu on your Handycam:
It may be worth a quick check to see what setting it is currently on.
If it is set to mp4 then change it to AVCHD and the quality should be much better
Let us know if you can.
