Hi all,
From UK. I have only sony handycam dcr-sr32E with battery charger that only charge the small piece of infoLithium, the original set I lost the cables. I am struggling to find the cables so that I can transfer all the video recorded to a computer but I have lost the whole set of cables. And without cables I won't be able to transfer it. Is there any way to solve this problem?? I appreciate the solutions and thanks for the solution in advance. I have this camera for so many years but I lost due to moving to the other country.
Hello @amankaur24,
which ports does your camcorder have? If you still got the AV cable, you can use a capture card to transfer the video onto your computer that way.
These usually cost like 15 pounds.
- Nic
