Hi
where can i get a replacement cable that fits the camcorder to a video player so Ican watch on my TV
Hi ana1109 and welcome.
Looking at Page 24 of your manual, it looks like a straightforward AV Cable. You can download your manual here:-
https://www.sony.co.uk/electronics/support/res/manuals/3865/38653341M.pdf
This is a direct replacement:-
https://www.amazon.co.uk/Cable-Mountain-Gold-Plated-Phono-Dark-Blue/dp/B0012LKFHE
However, you may wish to change one end of this depending on your VCR/TV inputs.
It looks like the sound is mono only so, if you will need to use this cable for other stereo connections, then the stereo cable below may be a better bet and you may want to get a stereo to mono adapter to use at the camera end.
AV Cable (example - find your preferred length):-
https://www.amazon.co.uk/Valueline-3-0-Male-RCA-Cable-Black/dp/B00HLDEV1S
Adapter
https://www.amazon.co.uk/Female-Phono-Sockets-Splitter-electrosmart%C2%AE/dp/B0051F8JM0
Hi
can I actually play the video from the camcorder direct to the TV? We no longer have a video player and were thinking we had to buy one
Thanks
