Hi
My phone (experia z2) "died" during an update of the Android system. I cant remember what update was called, but now it wont start and the only image that i can see is a picture of the android rodot lying down with a red warning sign on its open stomach. So what happened? And what can i do to fix it?
Hello Espenitos, this problem can be caused if there is insufficient battery power so you might want to try charging your Xperia overnight to see if the helps.
Also to save you creating another account in the Sony Mobile community, and then posting your question again, I did a quick search and found this solution that may be the answer to your problem.
