- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony bdv 3100
I have a Sony bdv 3100
and the last two outputs are not working now.. Never had an issue before but the speakers do work just not the ports
any solutions to this issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Did you test it with different speakers and cables?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yes the speakers work fine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It’s just the last two out put on the unit .. They just don’t work
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Niki6371, what do you mean with two outputs? Two speakers?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If your looking at the back of the unit
the last 2 jacks where you hook the speakers too does not work
i tested the speakers and they are working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does anyone have any idea as to how to fix this issue…
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey Niki6371, if you tested different cables, reset the device, and did the unplugging step, then you need to send it for repair: http://bit.ly/2DJn2JC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I unplugged the unit leaving it about 10 minutes and the speakers do work so I know that’s that’s not the issue
is there a fuse are something inside that I should check for?
