Hi, just a query regarding my Sony 1080 AV / Receiver FM Aerial connection, is it possible to obtain a ready made cable to connect directly from FM to an external FM aerial. The FM aerial cable supplied is useless in my area.
Would be very grateful for any response or have any ideas ?????.
Awaiting any info,
Regards :- chinoko1948
H there,
Have you tried to extend and adjust the position of the FM wire antenna (aerial) to a place where the reception conditions are good?
I would also suggest placing the aerial near a window or position it as horizontally as possible.
Best wishes,
Sean Mc
