The LCD stopped working. Since the camera is out of warranty I have carried out my own repairs. I have replaced the LCD screen, the small PCB attached to the back of the screen and the flexible ribbon cable from the camera to the screen. The LCD still does not work. It appears to have power but does not display an image or any information when the menu button is pressed. All other camera functions work correctly. Are you able to suggest a reason as to why the LCD is still not functioning correctly?
Hello @A77Sonyshooter,
maybe the sensor which is on the eye-piece is malfunctioning and therefore the screen is switched off software-side.
Just a guess.
- Nic
