I have a Sony KD49XE9005BU 49" 4K HDR LED TV which I am very pleased with, I also have a Sky Q box, I have just purchased a Sky soundbox and have connected it up to the TV etc using the HDMI and optical cables as instructed. Everything seems to be working fine and I am very pleased with the whole set up.
My question is, I have turned the sound down on the TV as there doesn't seem an option to turn the internal tv speakers off, which is fine if that is all I can do. Are there though any other set up options etc i need or can do to improve the sound even more.
Happy to hear you like the TV!
Have you checked the sound settings in the menu? May be options there you can try.
Thanks,
Drew
