I attempted to register a set of wireless headphones that were given to me as a birthday gift.
To successfully complete the registration form I have to provide details of date of purchase, town and store.
Why is this necessary? Should I need to bother relatives by asking them for what I consider to be irrelevant information.
Hi swellmel, if I am lucky enough to receive a Sony product as a gift I usually select Yes to purchasing Online (that removes the Town option) then type in the date I received the gift & finally select other for Store.
If you have a problem with your wireless headphones then you would probably need the reciept to return the product back to the store that they were purchased from or if it's from a large chain then your nearest outlet.
Hi Nobody-in-Particular,
Thank you for the advice, really appreciate that.
