Play Memories Home came with my Sony Camera.
When I try to save an edited video I get a message saying "PMBMCEWrapper 64 has stopped working. " Windows then shuts the programme.
This now happens every time.
I hvae uninstalled and re-installed the software but no joy.
Any ideas??
Hi @MichaelF2 and welcome to the Community
What version of PMH are you currently using?
Also what system do you have (e.g. is it Windows 10 64-bit?)
cheers
I am using Play Memories home Version 5.4.02.06120 which I think is the latest version.
I have Windows 10 64 bit.
Any help appreciated.
Anybody got any ideas? Should I go and buy a different video editor?
Hi @MichaelF2
You've tried uninstalling / reinstalling already so it may be worth
trying running it in compatibility mode for Windows 7 / 8 just to see if it makes any difference.
(find the .exe file - right click - properties - compatibility)
I have seen different program users have this kind of problem, but theirs was either fixed by
uninstalling / reinstalling software or by a fix issued by a company.
Some had success with the compatibility fix though.
If not then you'd be best contacting Sony Support
Thanks for the suggestions. I tried the compatability and it changed some things and told me to test. It didn't work exactly the same problem "wrapper stopped working".
I guess I will trySony Support.
Thanks for trying it anyway
