I have a problem with my Playstation 3. Lately, whenever I try to play a game it freezes horribly. The loading times are very long and there are pop-in textures everywhere. I am curious to know what is the problem. The hdd is okay, I put the hdd into a laptop to check if it's alright and it is, the blu ray drive is also alright because the hdd games that are installed have the same problems, if I would go to a sony shop and tell them to repair my PS3, how much will they charge me for this, should I go or should I look for someone not so experienced but cheaper? Thank you.
Hi hotshot95,
welcome to the Sony User Community forum..:smileyhappy:
For Playstation problems your best bet would be to post your question in the Playstation forum, I'm pretty sure someone will be able to help you with your problem over there..:smileywink:
Hi hotshot95,
