Is it normal every time that I try to login I have to "prove" that I am not a robot?
Alex.
Hi Alex, welcome to the Sony Community
Yes, unfortunately this sort of 'captcha' process on login is required to stop spammers and the like.
Recently it's become pretty annoying and takes a little longer than it should to recognise you as 'human'. We've reported it but apparently it takes a while to fix these things... sorry if you found it off-putting in any way.
Best wishes
Mick
Hi @Alex73L
Thats something a robot would say
Are you sure you're not a robot?
Welcome to the Community
