Hi all,
Received my 1st sony product 4 weeks ago - was pleased with the picture and functionality.
Unfortunately it now will not display a picture when turned on, all I get is the front red LED flashing at me 9 times between pauses.
How common is this fault?
What is Sonys response to this problem?
I have to decide whether to go for a refund or take a chance on another TV (going through my retailer as opposed to using Sony customer service). Do not fancy playing russian roulette!
Many thanks
LFW
Hi Thalamus,
Thanks for the response.
Yes, time to decide on refund or an exchange. Really do like the TV, great picture.....
I see you an expert, so pose the following Q's:
What is the common cause that is putting these TVs into self dig mode?
What percentage of TVs sold are experiencing this problem? - Sony will have this data, and it will also help me to decide whether I have a chance of success with a replacement.
The TV has been out for nearly a year, I would be interested to understand if the problem has been 'introduced' recently, i,e a batch issue? ir it has been ongoing>?
If the odds are against me for this model, (question open to all), what would be a good TV option for around the £800 - £1000. I was looking at the Samsung 6700 but I understand they have lip synch issues.
Many thanks
LFW
Hi there
Let me see if I can answer these questions for you.
Unfortunately experts are not given the full resources of Sony in regards to what the LED blinks are. The number of blinks indicate what type of fault and where to look. But basically, the blink code indicates a fault in the hardware (sometimes software). Sony Blink Codes change each year, and can be different depending upon the model number of the TV. For example, as far as im aware, last years W8 TV, didnt have a 9 blink code error.
Hope this helps you
Many thanks.
Your welcome
To update this story, I opted to give the model 1 more try, I have been sent a replacement set, so far, so good.
LFW
