In an attempt to go wireless with my guitars, I bought cordless transmitters/receivers which work fine together on two guitars and amp. Then I bought a set of Sony RF headphones so I could practice hopefully cordless completely. However the interference makes it impossible to use them. I have tried the three settings and moving the transmitter as far away as the headphone lead will allow, which needs to be connected to the amp. what more can I do to alleviate this problem.
Hi there,
Hopefully a community member can help.
Best wishes,
M
Hi Denthezen,
I've done some research on this headphones, and i can see that users connect it mostly to their music players or TVs. So, with kind of setup you have, i believe that interference could be normal.
I would suggest that you try connecting the headset to a music player or a TV away from any other radio frequencies to test if the same issue occurs.
Vanilla_
