It may be that I am using a mobile device or it may be due to the recent changes to this forum as I cannot select a post as the solution.
Is it me or has the option gone ?
Regards
Hi @Jonnie1266,
I just checked and can verify, that the button is not there in the mobile version.
I will forward this to @Peter_S.
- Nic
Hi @Jonnie1266,
- Nic
Cheers, thought I was going crazy
I would have accepted this as the solution but I’m on the mobile again !
Regards
