HELLO, rooobb,
ref my STRDH790AVR it does support D/V with alll do respect but whatever i do the
resolution stays misty grey with loss of image quality Ive got 2 D/VISION 4k discs Apocalyspe now
and the shinning when DV set on bdp only it makes little diff older movie perhaps not cleaned up
by film co.setting picture mode HDR to HDR10 helps a little but goes quite dark..
Hi there,
I think you might have meant to post this reply to a previous thread. If you can respond to the original post for further assistance.
Best wishes,
Sean
