I see Sony are now on the, 'Freeview Play', list of supporting manufacturers.
I assume this is software, if so can it be loaded onto a Sony KDL32WD756BU TV?
Hi Wagolynn,
Welcome to the Community. To access Freeview Play, you either need a TV with Freeview Play built-in, or a separate Freeview Play recorder, which you can link to your current TV.
Unfortunately your TV does not have Freeview Play built-in, so you would therefore need a separate Freeview Play recorder.
We hope this helps.
Owen
Hi Wagolynn,
We hope this helps.
Owen
Many thanks for reply, Owen.
Freeview Play will not load. It's hopeless!
