- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
flickering image on 100fps with the Sony fx6
Hi, my first time posting and was looking for some help.
I shot some footage in 100fps (25p) outside, so natural lightning without any source of artificial light and with a 180 degree shutter angle. It seems that I have come across an issue: the images are flickering a lot.
Maybe I'm overlooking something. I tried it with the same camera settings and circumstances one day later and it was fine without any issue.
Perhaps it's worth mentioning that I also used a 19,5 output D tap power cable to connect with the V mount battery.
I would appreciate anyone's thoughts on this. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey @Rogier_b
This issue may occur if the shutter speed is too slow compared to the frequency of the ambient light source.
You can try the following:
-Increase the shutter angle to 240 or higher.
-You can also try shooting at slightly higher or lower frame rates to see if this reduces the flicker.
-Make sure the cable is properly connected and not loose.
-Try turning off the image stabilization function: Capture - SteadyShot - Image Stabilization
-Also make sure Flicker Reduction is set to ON: Capture -Flicker Reduce
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hey @Anonymous
Many thanks! Next time when this issue occurs I will use your tips.
Kind regards,
Rogier
