I have a GXD360 DVD Recorder used just for transferring DVC camcorder tapes to DVD. Recently on applying power the message "WELCOME" appears, as normal, but doesn't go beyond that however long I wait. Disconnecting, then reapplying power does not change the situation. Is there a likely cause for this? More to the point, can anyone suggest a solution? Many thanks.
Hi Gordon,
Welcome to the Community.
You could contact Sony Support about this.
Thanks,
Pascale
