How can I stop my dvd player from making a loud humming noise when playing a dvd?
Hi There,
Since the player reads the data from a physical disc that's rotating at high speeds, It's inevitable for it to make such a loud noise.
You can possibly reduce it by putting the player on a rubber base to absorb some of the vibration.
Win_88
Thanks for the suggestion. Will give it a try.
