Hello,
I have following TV model : Sony 48 "LED Smart TV KDL-48W605BBAE
it supports
| DVB | C / T2 / S2 |
Also it supports:
| Approved by Boxer | Yes |
| Approved by Com Hem | Yes |
| Approved by Canal Digital Kabel | Yes |
| Approved by Canal Digital Satellite | Yes |
But I still dont get default channels in my TV. I live in Sweden. Can someone please point me out some settings in my TV which I am missing?
yes i am doing the same pic attached. no channels found yet.35306030_10155691674661342_822758705614290944_n.jpg
Hi @ali.electro,
did you check if the cable is connected properly to the TV? (At least it looks properly attached on the image you uploaded)
Also did it work with your previous TV?
- Nic
yes it looks to be connected OK.
I had same TV at previous place where I lived, but there the provider was different it was comhem and i had white cable there also but it wasnt same as this ( it was something which comes along with internet connection)
I have a different provider "Boxer" here.
In my previous place it worked fine with this TV.
Hello @ali.electro,
would you mind explaining the difference between the providers?
Your old one seems to have been a cable provider, your new one is DVB-T?
- Nic
both of them are ISP.
They provide internet as well as digital TV
Hi @ali.electro,
does Boxer need this little receiver to work (the one shown on their website)?
If not, why don't you give them a call and explain that you have problems setting your new TV up.
- Nic
yes I am thinking of calling them now.
thanks for ur quick suggestions
