Anyone help? I've installed a TP-Link Deco X60 AX5400 in my new home. My Sony KD-55A8 connects to the original wifi but is not being accepted to the new wifi network running through the Deco home mesh. Any support with solving this is greatly appreciated
@doughall_sa Have you tried wired connection with your device? To test if the issue with the Wi-Fi signal or the TV.
Thanks so much for this. I did a reset on the tv, router and home mesh and I could then connect the tv to the mesh.
