Does anyone know of a way of compalaining to sony management concerning lack of correct information, The arrogance of some of the support staff who dispite having two ears and one mouth insist that something will work when it is known it will not. And when you go to supposed higher level of support. the person appears to have little knowledge either. You ask to speak to a senior person and when you ask if there is any idea of timescale they say non at all. So I might get a phone call next year. Can anyone suggest appropriate action. Has sony become to big and arragant and know longer cares about its customers. Do we have to make them look foolish before they listen
What Sony product are we talking about?
Also a rough idea of what the problem is may help someone to suggest the right place.
Dont hit your head against the wall,sony does not have ears they are a sound system. my experience with sony after dealing with them and buying every thing sony is they only worry about profits.i have been grossly wronged by sony but all they say is one lie to cover the previous.right hand does not know what left is doing .and if atall any time they admit fault ,compensation is so paltryand also comes as a voucher so you put more money in to csh this voucher.global company with global lies harsh gulati
Hi there
Sony listens, and Sony cares - See the Sony Care Bear
Although, if you think you have a valid complaint, have you tried following it up? Or post a message on these forums with your issue, and maybe someone can help.
ROFL at the Care Bear.
That is superb Quinnicus!
You should see the X-Rated one, he doesn't have a white balloon covering his bits!
Dr.Slinky McVelvet - Inventor of the word 'Mellifluous' - 30.12.14
