Where is the spot removal tool? I have a new laptop now. I had to re-download the Capture One Software. The other version on my old laptop had the spot removal tool, now this version I downloaded yesterday does not seem to have it..or I cannot locate it. Can someone advise me? Thank you so much.
Hi Cynthia,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi Cynthia2017 ,
I found a brief description of the spot removal function. You can access it through this link: https://help.phaseone.com/en/CO9/Tools%20Appendix/Spot_Removal
There's a dedicated support for this app. You can find this here: https://www.captureone.com/en/support
Cheers,
The_Black_Rose
