Hello, my oled Bravia seems to have developed an audio issue since a software update in the last few weeks. PlayStation games are often crackly and the but ultimate channel is horrendously noisey. If I switch the power off to the tv only, so it restarts, it all comes good again for a while. Is anyone else experiencing something similar? Thanks in advance
Hi there,
Have you tried a factory reset?
Best wishes,
M
Hi Michael, I haven’t yet..... so many things to login/ setup again I thought I’d just see if others had experienced similar. It’s been ok today but usually it doesn’t last. I will try if it goes again, which I’m sure it will.
appreciate the response. Thanks.
After 5 or 6 power cycles, where it reboots rather than from standby, the crackle has disappeared......at least it appears to have gone for now.
thanks for the response
