Hi all,
Can someone please suggest a suitable miniature Bluetooth keyboard that can be used in conjunction with a Bravia 4k TV (KD-65XG8796)?
Many thanks Mark.
Hi Mark,
I would recommend the Logitech K400+ keyboard. It works like a charm (using it on my TV as well).
Unfortunately you cannot connect it to your TV directly via Bluetooth but it comes with a dongle that needs to be plugged into a USB port of your TV.
See also:
Thank you for your time Peter. I will take a look at that.
