Could someone tell me the Model Number of the Battery for a VPC M12M1E as I have lost mine . Thank You.
Hi PATIBBY,
as far as I can tell the batteries for the VPC M12M1E are as folows _
VGP-BPS21 - Standard capacity
VGP-BPL21 - Large capacity
You may be able to purchase these from Sonystyle.com.
If not then you should be able to purchase a replacement battery from Vaio support or possibly from one of Sony's authorised repair partners, to find the contact number for Vaio support.
Open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 1: Enter your vaio models serial number, which you should find on the bottom of your Vaio.
Then click Log-In
Once logged select Get In Touch
Then Click on the Out of Warranty tab, then Phone support.
To locate the nearest Sony service partner click on Out of Warranty Service tab
You may find cheaper prices for a replacement battery via Google but be aware than some retailers sell non Sony compatible batteries with the same battery model number..
Hi PATIBBY,
Then click Log-In
Hello Thalamus
Thank you for your reply on further reseach I found a reference http://www.sony.co.uk/product/vn-m-series/vpcm12m1e-w to the model number being VGP-BPS13B/Q and another reference listing the VGP-BPS21 and VGP-BPS13 as being the same.
Patibby
