Hi I’m looking for a base stand for my tv sony kdl-40BX400 as it will no longer go on the wall in our new house. Do you know where I can get one from?
Hello @Natasha2990,
if the stand is available as a spare part, you will find it here: https://eu.eetgroup.com/search?query=kdl-40BX400&b=570
- Nic
If you do not find or find something expensive... You can use the VESA holes, which you used to attach it to the wall, by purchasing a VESA table stand.
Manolo
