how do i open zip files?? have downloaded adobe reader, and sony reader but neither will load books into library.
Yes, all the above questions ditto
But, to open zip files you need a zip opener - sorry, but that's basically it !
You should have an unzip tool, if not google wiki to learn more about the subject, and download a tool if you don't have one.
You'll need to provide more information
What do you mean by zip files?
What reader do you have?
Have you authorised your PC and reader with adobe digital editions?
Where have you got your books from?
