I recently downloaded Reader for PC (OK - so I like to let things settle in a bit before I upgrade :smileygrin:)
However, since starting to use Reader for PC, I can't get rid of the "Do not disconnect" message on the E-Reader.
Using the old Reader Library, when I closed Reader Library, the "Do not disconnect message" disappeared.
I've tried
a) closing Reader for PC using the close button at top right
b) using Quit from the Reader for PC File menu
c) Using the Windows "Safely remove Hardware" button in the System Tray
None of those causes the "Do no disconnect" message to disappear from the E-reader.
So I have two questions.
1. How do I get this message on the E-reader to disappear when Reader for PC is closed?
2. While I'm in the situation where the message remains, what's the safe method of disconnecting the E-reader from the PC?
Thanks
PuppyDog
Message was edited by: PuppyDog
OK - found the disconnect reader icon. This stops the USB connection, but the "do not disconnect" message remains at the top of the e-reader. Is this just a glitch in the software, or is there still some sort of connection between reader and PC? Thanks
