hi, may be a stupid question but my reader is 2 years old and just starting to use it? Does it have wifi it is a prs-650 or am i just being daft? Thanks
No the PRS-650 doesn't have wifi, you'll need to use a USB cable and attach it to your PC
No, 'fraid not - sadly, that would have made it a kindle-beater in my opinion - hardware-wise, anyway.
If wifi is desirable for you, the T1 is the answer, and prices are now more competitive, but otherwise, the 650 is an excellent device - just stock it up with books so you've always got something new coming up !
Thje T1 is a great little device - but I'd say hang on to the 650 anyway, it's already a bit of a collectable, and a piece of beautiful engineering.
Pass it on to as an heirloom ?!
