Hi – I think this warrants a T2 software fix:
When scrolling through the Notes for a book, tapping a Note takes you to the relevant point in the text. But when you next bring up the Notes, you are positioned at the beginning of the Notes, rather than at the Note you last tapped. This is inconvenient if there are many pages of Notes, and you want to review them in sequence.
This is a retrograde step relative to the PRS-350, which worked as desired, so I think it should be fixed via a software update.
Btw can anyone tell me how to formally request such a change?
Thanks everyone.
