x
profile.country.en_GB.title
alliecurling
Visitor
syncing books
Hi
I am trying to sync a book on to my PRS-T1 and it will not go into the data transfer mode.
Please can anyone help??
1 ACCEPTED SOLUTION
Accepted Solutions
carpetmojo
Member
Have you tried resets at all - all in manual, quite straightforward.
Worth a try.
Remember to make sure you have all data saved if you go to a hard reset ...
1 REPLY 1
carpetmojo
Member
Worth a try.
