Hi yes this is perfectly normal, the unit does trickle discharge over time, it is not a fault
This could explain why I only get 2-300 pageturns from a battery charge, rather than the 6-7,000 advertised! My eReader has been back for repair to the battery twice since I got it in May, so not really impressed. Sony should be more honest in this.
So it's not just me then? I'd be delighted if my battery lasted a month, let alone several thousand page turns.
