Hi bought the prst1 for mum and setting it up i hav created an e reader account but when i try and access it is says email or password invalid but when i go on my pc it logs i ok any help really appreciated
If it persists, hit the "Forgotten Your Password " option, and change it when prompted to do so. Start again, basically - it's usually the password that's screwed up ....
I say if it persists, because I have fairly regular sessions of Sony refusing to accept my (correct) Forum password - after entering it around 4-6 times, it is almost grudgingly accepted, and I'm sure it's because the system senses I've just about reached the limits of my patience ! So do make sure you have done everything as per the manual, and the password's as your registration.
See your PM's.
See your PM's.
