I am using Readere for PC Version 2.0.00.07121.
I have specified that I am in the UK but the date format is wrong (mm/dd/yyyy) - is there a way to correct it?
The old Reader Library software got it correct (dd/mm/yyyy).
Brian
That it's default date format. If there is a settings page available, you can check it from there and be able to change it.
