My PRS 650 is frozen on a page in a book. Pressing the reset and using the power button hasn't cured anything. There is no red/green light or anything. What can I do next?
Hi I would advise you check it is fully charged, if the Reader is left on, it can be fully discharged with the last image on the screen.
Thank you for your suggestion as recharging has fixed the problem
