When connecting the T3 to the PC (WIn XP) it states "Disconnected" under "Info".
Why is this?
Hi
On specifications: http://www.sony.co.uk/support/en/product/PRS-T3/specifications
“Operating System
- Microsoft Windows 8 (32/64 bit) - Microsoft Windows 7 (32/64 bit) - Microsoft Windows Vista (32/64 bit) - Microsoft Windows XP (32 bit only)”
Have you made all required “steps”?
-Connect PRS-T3 on PC:
-Tap on Yes (and at the first time wait drivers installation and install ReaderforPC software).
-Open ReaderforPC (if prompted authorize PC and PRS-T3 with your Adobe ID).
-On ReaderforPC info it must be something like this:
(Sorry for Italian version!)
Jannis
PS
Adobe Digital Editions not compatible with Sony’s reader devices as PRS-T1/T2/T3.
| Non mi aspetto nulla. Non temo nulla. Sono libero. - I hope for nothing. I fear nothing. I am free. (N.K.) |
Same problem with prs - t1. no connection
