I have a prs-t1 that is in demo mode - it won't reset or turn off - help
Hi kelpat,
welcome to Questions & Answers..:smileyhappy:
The following should help you to deactivate Demo Mode on the Reader..
Follow these steps to activate or deactivate Demo Mode on the Reader Wi-Fi:
is being displayed, press and hold the Previous and Back buttons.
Could I suggest to all that it is always a good idea to scroll down looking at titles of posts to see if a similar - if not identical - post has been made ? It can save you time if you're lucky !
Sadly, I've found the Search facility here is ....useless?every time I've tried to use it !
This time I searched for "Demo mode/demo/demonstration mode/ demonstation/ ... you get the picture !
But, remembering an earlir post, I scrolled - and ye shall find ....
Post : " Re: Reader stuck in demo mode by yinhanna "
"My PRS-T1 is stuck in demo mode and won't connect to anything. How can I get back to the full softwa..." 2 replies, last reply 1 week ago by Lucie7059
Hope it helps. :smileygrin:
Hi kelpat,
can you please tell me how to solve REALLY this issue?
despite the "solved" tag - which is clearly non-true,
I have tried several times to follow this procedure and it ABSOLUTELY doesn't work
NEED HELP, THANKS
