I just got a PRS-T1 but the wifi connection failes:
Has anyone an idea what the problem might be?
The problem has been solved.
It was caused by a MAC filter in the router. After adjusting the MAC filter the wifi connection worked good.
I have the same problem. Can you give any details on how the MAC filter should be adjusted?
