Can you get a mains charger for the PRS-T1 reader? If so, from where? Or do we have to rely on using our computers/laptops?
Thanks
Faiq
There are a number of chargers that'll work on the Sony range - same one will work for 350.650, or T1.
You may well have one already! If it's for phone/laptop/mp3 etc... if it's got the right plug, and is, well, reasonable quality, try it ! if it works, there you go.....
However, WARNING, nothing that is for anything Apple-y ! They don't like each other, and they'll get sick....
You can get a dedicated one from Sony online , or you can root around on Amazon/ebay etc... But make quite sure it is compatible - and if it's very cheap, it is so for a reason !
And a PowerMonkey works, too, by the way, which is incredibly useful, they really are brilliant....
