Hi all, i was recently bought the prs 650. On the box it says you can download at least 350 books. I've done 64 so far and it's telling me it's full. Do i need a memory card and if so what size ect is best.
Thanks
Sounds like you're loading on a small card, not the main memory - that'll take over a 1,000, although I''m a bit tardy, I'm only up to 150-odd..........
But I do delete a lot when read.....
Hi
I am not sure what you have installed to your memory, but 2gb / 32 files would equal approx 64MB per book, maybe it would be best to look viaWindows explorer and see what you have installed, howevre yes you can add to the memory.
Did you add pictures or music to your reader, that takes a lot of space
GoodLuck!
eBookBoy
