PRS-650 blocked to standby
profile.country.it_IT.title
gds.78
Visitor
Hy, I have a big problem with my prs-650 buyed about 1 mounth ago.
Today it has blocked on the stand by image. I already try to use reset button without success.
I've just connect to my pc, but it's if how to nothing to do... so i'm very very worried.
Can you help me?
Thanks for your support
Best  Regards
g.
1 REPLY 1
profile.country.en_GB.title
Drumzman
New
Hi gds.78
I may be wrong, but it sounds like it might just be that the battery needs recharging.  The displays on eReader devices don't need power to display an image (which could be the reason you can still see the standby image), but do of course need power to change image or to switch back on from standby.
I think I'd try leaving it connected with the USB lead to your PC for about an hour to charge and hopefully it will spring back to life.
Hope this is the case!
