My PRS-300 battery won't hold its charge. Any idea where I can get a new battery from? Thanks
Not sure about the 300 generation, but the 6/350 on you (theoretically) can't do it yourself - and it's very expensive via Sony - but you could enquire.
Failing that , try youtube, I know there's a few tips on there, or MobileRead Forums, it's been mentoined there too .
You can almost certainly get them Staeside.
But basically, it's usually cheaper and easier to get another reader - I know, daft isn't it .....
